Trying to add Wi-Fi network causes Bluetooth crash
Just noticed today that my Edge wasn't connecting to wifi.  I "forgot" my network and now when I try to added it back the Bluetooth will disconnect between my phone and the Edge temporarily and the setup will fail.  Anyone see this before? I've tried turning everything on and off, and disconnecting and reparing the Bluetooth on my phone and edge and neither worked.
  • I think you can connect the device to your WiFi network if you are first connected via Bluetooth to a phone OR ... if you connect the device to Garmin Connect via computer. One or the other should work. Can you use the Garmin Connect with computer to join WiFi and then re-pair with Bluetooth? Shouldn't have to do this but maybe worth a try.
