After update to 25.25 Garmin seems to control kick move also multiple spontaneous reboots
I'm using a Wahoo Kickr Move with Rouvy and use a Garmin 840 to record my rides.
Since updating to 25.25 it seems the Garmin interferes with the Rouvy trying to control the Kickr.
For instance I'm seeing very low power readings and very high speeds in Rouvy. While the Garmin displays half the speed I see on Rouvy.
Rouvy is connected to the kickr through bluetooth and runs on a AppleTV. The Garmin is connected to the kickr using ANT+
After some experimenting I seem to get it to work as usual when tapping indoor profile first and then select "free ride". When hitting the start button after starting to ride seems to interfere.
I've seen this phenomenon mid ride as well. Also I have been getting spontaneous reboots.
Any one else seen this?
Before upgrading to 25.25 everything worked flawlessly.
Thanks,
Martin
  • Hello,
    today, after 1 hour riding, my garmin edge 840 completely reboot.
    Fw 25.25
    Garmin Cadence sensor
    Garmin Tempe
    Connected by bluetooth at my samsung phone
    "product_name":"Edge 840",
    "software_part_number":"006-B4062-00",
    "ms_since_epoch":1735304199000,
    "system_version":"25.25",
    "build_type":"PRODUCTION",
    "error_cause":"RTL Trap",
    "proprietary_info":{
        "Commit ID":"431794a65b73e0281ddcb3bb618cf5182977585b",
         "Ram Dump":"N/A",
        "ESht PC":"0x6047B071",
        "ESht SP":"0x62A060D8",
        "pageStack":"858",
        "pageStackDepth":"1",
        "RTL Error Number":"6E5D8024",
        "Error Message":"000011E6,D0BE3FF0,00000000,00000000,00000000,FFFF0000,D0BE2E12,618EF80A,622A162C,00000000,6232A31C,61EB0B6C,FFFFFFFF,6232A1C0,6100A4C8,6100639C,600F003F",
        "Task Name":"BTF main",
        "Saved SP":"6232A1C0",
        "Saved LR":"6100A4C8",
        "Saved PC":"6100639C",
        "R[0]":"0x000011E6",
        "R[1]":"0xD0BE3FF0",
        "R[2]":"0x00000000",
        "R[3]":"0x00000000",
        "R[4]":"0x00000000",
        "R[5]":"0xFFFF0000",
        "R[6]":"0xD0BE2E12",
        "R[7]":"0x618EF80A",
        "R[8]":"0x622A162C",
        "R[9]":"0x00000000",
        "R[10]":"0x6232A31C",
        "R[11]":"0x61EB0B6C",
        "R[12]":"0xFFFFFFFF",
        "R[13]":"0x6232A1C0",
        "R[14]":"0x6100A4C8",
        "R[15]":"0x6100639C",
        "cpsr":"600F003F"
    There is a fix to this problem ?
