Edge 840 Series Version 24.18 - 20% Rollout
Firmware version 24.18 for the Edge 840 Series is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
20% Phased Rollout as of 9/9/2024
Changes made from version 21.18 to 24.18:
  • Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
  • Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
  • Added GroupRide awards and climb competitions.
  • Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
  • Added wind and stamina adjustments to Power Guide.
  • Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
  • Added Wi-Fi map download support.
  • Added revamped Course Creator.
  • Updated grade algorithm to be much more responsive.
  • ClimbPro
    • Fixed climb clusters failing to display climb details.
    • Fixed an issue where the climb list page could highlight the incorrect current climb.
    • Fixed climbs drawing on a course when ClimbPro is disabled.
    • Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
  • Added support for India basemap.
  • Added gear presets for SRAM 12 speed cassettes.
  • Added a QR code to quickly pair a Strava account with Garmin Connect.
  • Added search alias support to improve location searching.
  • Added course search to the search bar.
  • Fixed USB connection detection when coming out of suspend mode.
  • Fixed crash that could occur when saving the ride.
  • Fixed incident detection countdown timeout notification priority over any other notifications.
  • Fixed infinite elevation calibration prompt following a manual calibration.
  • Removed tone from elevation calibration prompt.
  • Fixed mute toggle interactions on the notifications widget.
  • Fixed pausing navigation.
  • Improved speed of city search.
  • Improved phonetic and hand-writing keyboard input.
  • Fixed ride button failing to show after receiving and reviewing a Connected POI.
  • Fixed friendly name for phone pairing.
  • Fixed issue where hazards in China could appear offset on the map.
  • Set minimum backlight level to retain screen visibility after backlight timeout expires.
  • Persisted backlight level setting through battery saver enable and disable.
  • Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
  • Fixed display of battery level when it dropped below 5%.
  • Fixed small roads on map being drawn too thick.
  • Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
  • Fixed an issue where British coordinates could not fully be entered with the keyboard.
  • Improved layout of post-ride highlights page.
  • Fixed various crashes and freezes.
Changes made from version 21.17 to 21.18:
  • Fixed potential crash and lap data loss when turning the device off mid-ride
Changes made from version 21.16 to 21.17:
  • Fixed connection issues with BLE sensors that do not support secure connections
Changes made from version 20.19 to 21.16:
  • Added support for button control and trim adjustments for SRAM AXS shifting systems
  • Added the ability to send and share locations from Apple Maps
  • Fixed glance refresh issues on the main page
  • Added lap ascent and descent data fields
  • Fixed solar graph display on post-ride highlights page
  • Fixed courses with special characters not loading properly
  • Fixed connectivity of Polar Verity Sense
  • Fixed an issue with GroupRide course downloads
  • Fixed issue where lock on road setting was not being honored
  • Fixed issue where true-up activities could not be deleted
  • Fixed frequent disconnect issues with 2M PHY connections
  • Fixed an issue causing excessive battery drain during suspend
  • Fixed an issue with real-time settings data screen layout editing
  • Fixed partial display update issues with suspend mode
  • Fixed issue where BLE sensors would not connect
  • Fixed potential issue where segments on the filesystem were not drawn on the map
  • Fixed audio prompts for speed
  • Fixed issue with elevation calibration prompt appearing repeatedly
  • Fixed off-segment tone issues
  • Fixed VO2 display on four-week history graph
  • Improved default connection interval for BLE peripherals connected via Connect IQ apps
  • Fixed issue causing translations to be removed
  • Fixed crash when importing large GPX files
  • Fixed road lines being drawn with the wrong style
  • Fixed issue where auto brightness would stop working
  • Fixed crash when drawing the alpha mask for CiQ icons
  • Fixed hourly wind speed display
  • Fixed workout comparison graph in ride history
  • Fixed gear battery data field for certain ANT sensors
  • Fixed CiQ data fields with developer data not appearing correctly
  • Fixed issue displaying courses on certain maps
  • Fixed positioning issues near Chinese borders
  • Fixed searching issues with Japanese keyboard
