Incorrect position on map
Hi all!
I really need help because I can't use navigation on my Garmin. The problem is that my position on the map is always displayed about 300m to the east.
At the same time, GPS works correctly, tracks in Garmin Connect are uploaded perfectly. But navigation and Climb Pro are not working at the moment, as it displays my position not where I am going. Presumably this started after the last map update, when I installed the Routable Cycle map of Middle East & Central Asia 2024.10.There is a feeling that the map is being linked to the wrong starting points.
Reinstalling the maps and master reset did not help. Firmware is 21.09.
Thanks a lot
  • What country are you in. China has a GPS offset that needs a special security fix on the Edge to over come the position offset.
    This was fixed in 21.13
    • Fixed issue where ride track could become shifted on the map
  • I'm in Kyrgyzstan, it's pretty close to China.
    I installed 21.14 now, unfortunately, the problem remained(
    UPD: I walked through the forums on how to remove the Chinese offset. Deleting file 006B082300.bin from the root folder worked.
    Thanks for the direction of the search!
