The lights are Bontrager RT lights. Everything worked well for a couple of months and now not so much. Both sides of the power meter shows up on the 4iii app.
I am having exactly the same issue with my 4iiii Dual Power meters and my Garmin 830
If you are pairing over ANT you only pair to the controlling side of the power meter. The controlling side then manages the communication with the other side.
You may need to make sure that the two sides of the power meter are paired together.
Have paired them in the 4iiii app so all good there. I then see just one ANT number which is what 4iiiii said would happen. But still am not seeing balance data which is confusing me. So now contemplating over a beer
That sounds like the correct configuration. Does the total power number look correct? Try doing some one sided pedaling and see what you get.
