Hi all,
In my case, I have TOPO Czech v5 PRO. So I used Garmin Express, redeemed the code and clicked the install button. I got the green message "Installation complete". That is easy.
Device rebooted.
How to confirm I am using a new detailed map, instead of a standard one? Where to check what map is used?
I see no visual changes in the device.
In the Garmin Express button "install" is still active]
In the manage map menu, I do not see the new map in the list
I found no menu inside the device to check the map name.
Thanks
