Edge 840 freezes after ejection from Garmin Express
Hey!
After I do anything in Garmin Express with my 840 and once done right-click on it to eject it, the devices freezes in the screen you see below. Only thing that helps is to force a restart.... Latest Garmin Express and Firmware (19.22) on device installed.
I tried a complete reset as well already, but the behavior stays the same. Anyone has the same issue or has an idea what I could try?
Thanks a lot!
  • I'm using a M1 Mac with 14.2.1 (Sonoma)
    I really hope it can be fixed, its so annoying that such an expensive device cannot be used properly with a mac/pc.
  • You may need to try doing a reset. You can backup your settings so that you can restore them
    On the Edge go down in to the Garmin folder and select all the folders expect the SQL folder and copy them to your PC.
    Don’t copy the files in the Garmin folder otherwise you will be there all-day copying maps.
    Follow the guide below to decide which files you need and where to place them on the new unit or the original unit after a reset.
    You can either do a reset from an option under the System Menu -> Device reset -> Delete Data and Reset Settings
    or
    With the unit powered off hold both the lap and start buttons and power the unit on.
    On you PC you have the following folders
    Folder Name
    Contains
    Restore contents to this folder on the new unit
    Activities
    Activities
    Activities
    Apps
    Connect IQ apps
    Copy prg files to Apps
    Courses
    Courses
    NewFiles
    HMD
    Screen layouts for HMD
    NewFiles
    Locations
    Saved locations
    NewFiles
    Records
    Personal records
    NewFiles
    Segment_List
    Leader board selection for segments
    NewFiles
    Segments
    Segments
    NewFiles
    Settings
    User profile and sensor pairings
    NewFiles
    Sports
    Screen layouts
    NewFiles
    Summary
    Activity summary from other devices
    NewFiles
    Totals
    Activity totals
    NewFiles
    Workouts
    Workouts
    NewFiles
    Multisport (Watches only)
    Multisport settings
    NewFiles
  • Thanks, but I already did tow complete resets. Didn't change anything Disappointed
  • I used Garmin Express on PC. Uninstalling the following data fields helped: MY EDGE2, SPH Graph, WindField, OldTimer. I don't know which of the above was causing the problem, but once uninstalled it doesn't freeze the 840 when disconnected from the PC. Software version 19.22
  • Do you also have any CIQ apps installed? Is so could you list them and I will see if I can reproduce the issue/
  • I installed the 4 CIQ apps mention above and was not able to reproduce the problem.
  • THis has been happening to me for a while and I was emailing Garmin about it. They never figured out what was going on. They just stopped replying to my emails.
  • Hi Guys, it happened to me too, and it disappointed me quite a bit!
    however I can tell you with certainty that the problem that the device freezes depends on a map installation problem. they must be reinstalled. And please do it via a PC with a USB2 port and the original cable.
    I reinstalled the maps, but I read that Garmin suggests removing it first, restarting the device (by disconnecting and reconnecting) and finally reinstalling the map. In this way my device no longer froze, it no longer gave me the "failed to get basemap version" problem and it restored the climbpro function.
    Let me know.
  • This isn't a problem with these apps - today it still hangs when disconnected. I will check the method of uninstalling maps.
  • You're absolutely right! I uninstalled all the original maps and after many tests it doesn't hang when disconnected from USB! I will check what will happen if I do a clean installation of the map: "Routable Cycle Map of Europe - East"
    Without maps it works perfectly and doesn't hang Slight smile
