Not sure if it is a setting I've changed without knowing but when Climb Pro pops up, I seem to sometimes get two different layouts appear.
One has just the elevation graph, dist to go, elevation to go and my two data fields, and the other layout has the same but with a small rectangle field at the top that is a map (plotting the climb)
Does anyone know what determines which screen layout appears? Pretty much one without a map and one with.
I was thinking maybe it depends if the climb has a turn that needs to be made in order to stay on that particular climb, so it displays that for you to warn you. I will do more testing and some screen shots if need be.
Thank you
