19.22 regress's the intensity minutes issue of them not showing up in connect. This was fixed in the previous version, but is once again broken.
Ok so the bug continues. Three rides on the trainer this week with the 840. 1st ride - zero intensity minutes. 2nd ride 173 intensity minutes (correct), third ride, zero minutes...
Another day and another failure to record intensity minutes.
Test today - uploaded 840 to connect before allowing Zwift to upload to Strava and synch with Garmin. Success - all data including intensity minutes correctly showing in Connect.
...and failure after doing exactly the same thing the next day...
I did send them amounts of examples months ago. Still they did not fix it. My Garmin now back on its way to the vendor, since there were other clown-bugs. not going to pay this amount of money for this quality.
Same issue here (840). Erratic behavior
Erratic behavior here to. One day just a few, not all, minutes, another day noting, and yesterday it worked as expected. I suspect server side processing issues.
I believe I have a solution which may help. I have an edge 1040 and have found that if I sync it to Connect before I end the activity intensity minutes, calories and HR details transfer across successfully. I then end the activity and sync again to download the activity details (mileage, duration, etc, etc). Hope that helps.
