I am using a Garmin Edge 840 Solar, and I have Version 18.25 installed. When I was doing the update, I also updated the maps, and now there is an error with the maps and navigation (not sure if it's related). I also think I might have also added the Europe maps. Do you think that messed it up?
When navigating, it would give an error on calculating the route (it would be stuck at 0% and then say "Route calculation error"). When I go to the Map screen, it definitely seems messed up, missing streets, partial maps, etc. On the boot-up screen, I get a "Failed to get basemap version."
Under Map Options, it says "Routable Cycle Map of North America 2023.10", and when I click re-install Map, it completes the installation to 100% and then indicates some kind of error.
PS - Honestly, so frustrated with the Garmin software; first time owning a head-unit and this is the second annoying problem of this kind owing to software I've had. Is the expectation we keep mucking about in file folders, or will they eventually figure it out? Gesh.
