I noticed, that since 18.23 I can't set or edit Connect IQ alerts
When I click in the alerts menu on Connect IQ Alerts, device freezes, so only hard restart helps.
Devs, any ideas?
Devs, any ideas?
What CIQ items are you using?
You mean CIQ apps?
I have 2 of my own, those are not in the store. and I tried a few random apps with data field alert functionality from the store. all the same. device freezes when I turn the alert setting on
Would you be able to give an example of one from the store I could try to see if I hit the same issue?
Here it is:
https://apps.garmin.com/en-US/apps/6e4dd285-731e-4200-b236-bf878bf91b12
https://apps.garmin.com/en-US/apps/12beb4ec-d915-4681-8b4f-228a8481cf4b
To reproduce:
install the apps, add the data fields to a data screen. then activity profiel settings =>"alerts and promts"=>"connectIQ"=>
choose the app, click in, toggle the on-off switch. After the toggle my device freezes.
After hard restart, it freezes in that activity profile on the click: "alerts and promts"=>"connectIQ"
I get the same. I will raise a support ticket with Garmin.
thanks a lot.
I tried to get something from garmin support, they blamed the apps, and refused to help
Hello @Artem do I have your permission to reach out to you directly outside the forums?
Hi Maeve, you have the permission:)
