When first paired my SRAM XPLR 1X with the 840, I got a battery field that showed the RD and both shifters. Now I only get the RD battery level. How do I get the original field back?
I found an older post on the Garmin 830 forum that said to re-pair the shifters with the RD to get their battery levels showing on the Edge. I'll give a try in the next day or two and report back.
Check if SRAM fw update is available, too. I had the same problem with Eagle xx1 and Edge 830 and it is now fixed with fw update. Use SRAM ASX app on mobile to check fw, not edge device.
Indeed. Went to the bike to try re-pairing the levers and RD and saw an update was available for the RD. Did the update and now all three battery levels are showing in the battery field.
