Light network set to "on when timer starts" but doesn't pause when stopped.
Bit of a weird one: I have a Varia RCT715 and a Bontrager Ion 200 paired via ANT+ to an Edge 840, as a network. ("Light network formed" message)
It's set to activate "on timer start". OK, fine.
Weird behaviour is the lights don't switch off when the timer is stopped. Effectively, once the light network is active, it stays active until the device is powered down.
Is this normal? If so, it'd be nice to see a system update to switch lights off when stopped.
  • I have the 830 with RCT715 and UT800 set to start at 10km/hr, manually stopping the ride, the lights remain on, they only switch off after you have saved and uploaded the ride. They they both switch off and go into bluetooth polling mode ie sleep mode.
