[bug] 24h clock set in options, however Edge 840 shows time in 12h format
24h clock set in connect web options, however Edge 840 shows time in 12h format (and it has 12h set on device)
  • I have the same issue. Also distance units refuse to change from miles.
    Did you manage to fix this?
  • The settings to change your units of measure can be found under Menu > System > Units on the Edge 840.
    From here, you can edit the Time Format (12 Hour, 24 Hour, Military) as well as Distance and Speed (Statute, Metric), Temperature (Statue, Metric) etc.
    After you edit those settings, sync your device.
    Please comment if your settings aren't maintained when viewing your activities in Connect or on device.
