Edge 830 set intervals fail and bug
Hello!
I would say "intervals" feature on Edge 830 (with latest SW 9.75) has BUG.
When you are in an active indoor cycling training with the 830 and with ZWIFT HUB smart trainer (without ZWIFT app),
you set a target power like 150watt works okay,
but if you want to start an intervals and edit/modify the data via "edit", then when you press "Do workout" it starts the previously SET intervals not the one you entered. That is lost, never see that again.
Reporduction
  1. Start indoor cycling training on 830
  2. 830 is connected to smart trainer
  3. set target power
  4. edge 830 starts to set that power on smart trainer, goes okay
  5. go back to Training menu without pausing the activity
  6. go "intervals" -> edit
  7. Edit your intervals data with new watts, durations, repeat, etc
  8. then go back and press "Do workout"
  9. Workout starts, but
  10. BUG: it starts the interval BUT with previously SAVED data, newly entered DATA has been gone, you never see it again
    you need to stop the started interval etc...
Definetly an UX BUG
Garmin, please FIX it!!!! very annoying as you cannot use this feature and totally screws up your training.
