Edge 800 Data field changing
AT the beginning of a ride, after I have set my training page for no apparent reason the unit highlites a randomn data field in blue, and then attempts to edit it.  I can get back to the training page by hitting the back button.  Sometimes it randomnly changes the data field from one selection (distance) to another (time to go...).   I am not touching the unit and the physical jarring of the unit does not cause any changes.
This goes a away after about an hour of riding and does not retrun.
Other than that the unit records accurately.
Any ideas!
  • I just noticed this happening recently, also, and got on here to see if I could find any info. I suspect it has something to do with sweat dripping on the screen. When I long press a data field, it will highlight and then I can either tap it again to change it/remove it or tap a different data field to swap their position. Honestly, it is pretty nice if you mean to do it, but I had it happening on its own several times on my last two rides.
    Does anyone know what this "feature" is called so I can figure out how to disable it?
