my power zone 7 with 0 minutes
Good morning,
On Garmin Connect in my time report concerning the power zones, for all my sessions I always have 0 minutes in zone 7 (neuromuscular) with which I often exceed the maximum value of zone 6. Before with my old meter ( EDGE 810) I had time in zone 7.
Does anyone have an explanation?
  • Check that the zone is correctly defined on the Edge.
    If you post an activity file in FIT format I can check the value.
  • Hello,
    Thanks for answer.
    The zone are correctly definied on the Edge and my Garmin Connect.
    I found this topic. I will check this afternoon if I can help me.
    forums.garmin.com/.../edge-530-not-showing-time-spent-in-power-zone-7-if-i-create-trainings-on-smart-trainer-with-zone-7-it-doesn-t-work-zone-6-and-all-other-are-fine
    I look for a solution for share file .fit at you
  • I have the very same issue with my Edge 530. Although I spent some little time in power zone 7, garmin connect (web or mobile app) shows time 0:00 spent in this zone. The very same activity in Strava shows for instance time 3:30 in the power zone 7.
    I have asked this via Garmin support chat and they did not help much - they told me Strava and Garmin use different algorithms for the recorded data processing and therefore there can be differences there. I am not very satisfied with this answer.
    It is not crucial for me to have these zones shown properly but I would like having it in working state or at least knowing why there is 0:00 reported in the graph. I was thinking whether it is really garmin's algorithm and maybe I would need to spend in the power zone 7 much more than 2-3 minutes. I did not focus on the power zone 7 in my rides, I commonly have just some peaks there during 1.5-2 hour ride and maybe Garmin filters those and evaluates I rode 0 minutes in the zone 7.
