My Edge 830 is running version 9.75. Many years/iterations ago (Edge 800?) I found the "ETA at Dest" field - time for completing a route - to be quite accurate after a few hours. This is no longer the case. I took some photos of my gps from a recent ride and the table below contains the results. For some reason the Edge is using a wildly incorrect expected speed. On the left is the raw data from the photos. The middle is the calculated predicted speed that the ETA represents given the remaining distance. The table on the right is what the ETA would be if it was calculated from the average speed up to that point.
Can this be fixed so it is useful again? Is there some logic behind the current behavior?
| Data from Edge 830: | calculated from remaining dist/avg speed/current time | |||||||
| current time | dist to dest | avg speed | garmin eta | calculated predicted speed | hours to dest | eta | ||
| 07:00:00 AM | 124 | n/a | n/a | n/a | n/a | |||
| 09:20:00 AM | 94.08 | 13.4 | 08:27:00 PM | 8.46 | 7.02 | 04:21:15 PM | ||
| 01:58:00 PM | 43.85 | 12.6 | 06:58:00 PM | 8.77 | 3.48 | 05:26:48 PM | ||
| 03:47:00 PM | 25.27 | 12.5 | 06:17:00 PM | 10.11 | 2.02 | 05:48:17 PM | ||
| 04:00:00 PM | 14.25 | 12.7 | 06:00:00 PM | 7.13 | 1.12 | 05:07:19 PM | ||
| 04:55:00 PM | 9.93 | 12.7 | 06:00:00 PM | 9.17 | 0.78 | 05:41:54 PM | ||
| actual finish time: | 05:40:37 PM |
