Have created a number of workouts in Garmin Connect, using power as the primary target for a number of intervals, no secondary target. I prefer to manually chase particular power levels, rather than have the Kickr set the resistance as in ERG mode.
Transfer of workouts to Edge 530 works fine, and workouts also display fine on Edge 530 having paired my first edition Kickr as a power sensor to the Edge 530.
The data fields on the Edge 530 called either "Target" or "Target Power" return a zero value in each case when doing the workout - despite having set a particular wattage level for each interval in each workout.
Does anyone know how you get the 530 to display the set power level for that interval in the workout as a data field on the 530?
When doing the workout, the Edge tells you if you are too high or too low and what the required watts are (so it know the selected figure) but a data field updating continuously would be more useful.
Anyone know how to get such a display working?
