It was working for a while after my return, but the above cycle began when I tried to switch it off...
PeteMas it sounds as though your Edge is stuck in a boot loop. To resolve this:
Try forcing your Edge to mount to the computer:
Unfortunately I still could not get the device to show on the computer. Powering the device off is only possible by holding down both the power button and the Lap button at the same time, The computer does not seem able to open the Garmin folder whether the device is switched on or off...Do you have any options for return?
Check to make sure the cable you're using is either a Garmin cable or a data cable. Using a regular USB cable would only charge the Edge, and would not allow it to be recognized by your computer as a drive.
If using a Garmin cable makes no difference, please reach out to your local Garmin Support Team for further assistance.
