Since the recent 9.73 upgrade...my h/r sensor is not auto connecting consistently( I have to go in and manually "connect" it). Never had the issue until the recent upgrade. I also changed the strap battery to make sure it had a signal. I have done a soft reset. It seems a little better now..but it will sometimes need to be manually connected.
And on my bikes without a wheel sensor, it seems my speed and average is a few mph lower and the auto pause happens a lot and takes a while to restart. This is while MTBing. It just started happening....and there are no leaves on the trees to block signal. It also ends up with shorter mileage. It does seem a little better since the soft reset....but was not a problem before the upgrade ( and under heavy leave cover)
Any ideas?
