Hello,
Today I experienced really weird behavior. Once I finished my activity I realised the actual end on the map was somewhere else (start and finish should be same location). My activity is partially missing coordinates. I didn't realised something is wrong because I use speed sensor and speed was displayed correctly all the time and also distance was OK as well so there wasn't any indication something is happenning. I started to see quite often speed sensor dropouts during my last few activities. I use autopause feature and speed sensor is helping me to not pause my activity every time I have weak GPS signal in the forest or while climbing on low speeds where GPS speed sometime drop to 0 for short amount of time. Sensor dropout triggers autopause and thats probably caused I stopped receiving coordinates after several unwanted sensor reconnects followed by pause/resume sequence (this is just my theory).
When I connect Edge to my computer I found err_log.txt file with todays date so this could bring more lights into this problam I experienced today. Attached you can find mentioned error log file and related activity fit file.
Not sure if this is right place to report issue.
"unit_id":"3366955986",
"product_name":"Edge 830",
"software_part_number":"006-B3122-00",
"ms_since_epoch":1672146434000,
"system_version":"9.73",
"build_type":"PRODUCTION",
"backtrace":"
Function Address: 0x6047CD4C
Call Address at Function: 0x6047CEE0
Function Address: 0x607A9440
Call Address at Function: 0x607A96A4
Function Address: 0x607A9BF2
Call Address at Function: 0x607A9D4C
Function Address: 0x607A9DC2
Call Address at Function: 0x607AA5A4
"error_cause":"RTL Trap",
"proprietary_info":{
"Commit ID":"39e670f78686e447f6c9b533f636867e5600492d",
"Time":"2022-12-27 14:7:14",
"Project Specific":"2022-12-27 14:7:14",
"CDP_LOG":"60624759,60477BC1,60649BB1,6064B081,60477BC1,60622F69,60610E69,60477BC1,60649BB1,60649BB1,60649BB1,60622B61,60649BB1,60478981,6060A995,6021C069,60218CAD,60605891,60218CAD,6021C069,6060A995,60478981,60649BB1,60622B61,60649BB1,60623985,60649BB1,60623985,60649BB1,60623985,60649BB1,60623985,60649BB1,60623985,60649BB1,6064B081,60649BB1,6062EC65,60621E91,60621E81,60651141,6064D759,60625C21,60217319,60622CA1,60217319,60477BC1,60611305,6062458D,",
"RTL Error Number":"6E5D802C",
"Error Message":"6047CEE1",
"Task Name":"SYC main",
"Saved SP":"63377940",
"Saved LR":"6047CEE1",
"Saved PC":"6047CEE1",
"R[0]":"6047CEE1",
"R[1]":"00000000",
"R[2]":"00000000",
"R[3]":"00000000",
"R[4]":"00000000",
"R[5]":"00000000",
"R[6]":"00000000",
"R[7]":"00000000",
"R[8]":"00000000",
"R[9]":"00000000",
"R[10]":"00000000",
"R[11]":"00000000",
"R[12]":"00000000",
"R[13]":"00000000",
"R[14]":"00000000",
"R[15]":"00000000",
"cpsr":"00000000"
