Cadence with SRAM Quarq
I have added a SRAM Quarq power meter to my bike, which is working fine for watt readings.  Until now, I've used a dedicated cadence sensor.  Can I delete this sensor and use the Quarq to deliver the cadence info to the Edge 830?  How to go about this?
TIA
  • I would simply disable your existing cadence senor under your sensor settings on the Edge. Then do a test ride to ensure the Sram Quarq power meter is providing your cadence. If your power meter provides the cadence, then I would move forward with removing the old cadence sensor completely.
  • I've got sram quarq too. No problems reading both power and cadence. No need for a dedicated cadence sensor.
