Hello
Is possible to show on map, the routes that i traveled in the past ? I set the history color, but in map i cant see any line in the trails that i ride.
Hello
The directions to always display the course can be found using the link below.
If you are referring to "Rides" that you have actually rode as opposed to following a "route" on the Garmin, then the answer is no. You can set the " history" colour but that will only show to where you have just ridden whilst riding. Once you clear the Garmin after that ride, that history will be lost and cleared from the map.
But, if you go into "history" and create a course of the ride you have just done, then you can set a colour to it and have it permanently displayed and that way will work along with as many other rides which you do the same to.
Otherwise, if you are just following a route, just do as the others suggest.
