Or at least, how to disable all navigation alerts, sounds, map and text direction?
Here is the use case:
There is a route on which I compare myself to my best ride, loading a recorded route and the Virtual Partner (VP). So far, no issue.
I take this route 3 times a week, needless to say that I don't need navigation guidance.
For every alert, navigation guidance takes space on the screen when I would read usefull training information and the frequent navigation beep are parasiting usefull training alerts.
I could not find a way to have VP without navigation/navigation alerts.
I removed map guidance to only text guidance but NO guidance is required.
Did I miss something in the set-up options?
Any of you has a work-around?
