Navigation Start From a Casual Ride
Often I start a workout ride with no particular destination in mind, i.e. not "navigating." If at some point, I wanted to start navigating to a particular address or start point, can I do that without saving the ride I'm on and starting over from the present location? If so, how do I set that up. I was on a ride this morning, about 25 mi from home, and decided to head back home but wanted the 830 to show me the way, I tried a couple things (I'm new to the device), but nothing obvious to me showed as menu choices. So.... I'm looking for specifics, not a "yes" you can do that....
Thanks in advance!!
  • Yes.  Recording and navigating are entirely separate.  You can start recording, pause recording, start it again, and even power down between.   Recording will continue until you pause/stop and either save or discard the ride.  What you do navigation wise is unrelated to recording.  You can start nav, stop nav, change to a different course, etc.  None of that will affect active recording. .
