In the edge 830 the warning "shift system, low battery" appears at least once every output
But it is actually heavily loaded.
Thanks
I am having the same issue. Just installed my Di2 system about a month ago. Garmin datafield shows battery level at 80%, but I'm getting the pop-up system warning,"Shifting System Battery Critical". I just spent some time with Garmin support and they weren't keen on recognizing anyone else having this problem. Only suggestion was to remove the Di2 system and reinstall.
Just curious if you have an 11-speed or 12-speed Di2? I have 11-speed so shifter is fully wired without a separate battery. I'm wondering if there's a bug where Garmin is incorrectly looking for the battery in the 12-speed shifter and can't find it...
