relevant devices:
- Garmin Edge 830 (bought and used since jan 2022)
- Favero Assioma DUO (bought and used since 2020)
First time posting so I hope you can see the picture clearly enough. Just in case, I have it also on imgur: https://imgur.com/a/GLbjyTR
I noticed during my last ride home (post club ride drink) there was a repetitive pattern in the speed registration. The disturbance itself is also the same each time.
Below is a zoom-in on one of them but they are all the same.
During the club ride, I noticed that my 3-seconds wattage data was also not as reliable as it should. It seemed to follow a similar pattern whereby the value would be too high and then too low, too high and normal again but it was more continuously throughout the ride. I don't know if this is related but it would be very coincidental. But afterwards, looking at my power data I don't see any real issues or similar pattern although I must say that it does show a higher up and down pattern for the more stable stretches when comparing to previous rides.
When I look at the speed recording of the club ride, I notice that the recording is not very smooth.
Below you can see for example how it goes up and down slightly. This is on a straight piece along a channel. It should have been a very smooth line.
to compare, from another ride where there were no issues, you see how the curve is much more smooth on a similar straight piece
It almost looks as if at some moments, the speed recording is based on the wattage meter instead of gps.
It is also the first time that I rode the bike at below freezing temperature. Maybe it is just an issue of needing power meter recalibration? But would it influence the speed?
