Hi everyone,
I have an Edge 830 and wanted to install USA maps for the Tour Divide.
Can anyone help.
TIA
Rob
Go here: https://extract.bbbike.org/
Download the area(s) you are interested in in Garmin format. Use the Latin version as the UFT one won't work.
Copy the map file into the \Garmin folder on your device. Go into the map options on your device and make sure the area is enabled when you go there.
This one is on line: https://extract.bbbike.org/
