A new Beta software for the Edge 830 has been released. Full change log, instructions, and software for installing the beta can be found in the link below.
Edge 830: https://www8.garmin.com/support/agree.jsp?id=14955
Notes:
- For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
- Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 9.24 to 9.26:
- Fixed software crashes caused by encrypted CIQ programs that are no longer valid.
- Fixed a couple of device stability issues.
Changes made from version 9.22 to 9.24:
- Fixed automatic maximum heart rate detection.
- Added the ability to perform the FTP test with power data coming from a trainer.
Changes made from version 9.20 to 9.22:
- Changed gear battery data field to display percentage remaining if available, which affects Shimano Di2 single-battery systems.
- Updated sensor low battery prompts to differentiate between low and critical status.
- Fixed issue where distance could stop accumulating.
- Fixed issue where text message sender names would display incorrectly.
