I have just bought a new Edge 830 to replace my old 800 which has gone a bit AWOL.
How can I transfer the OS maps from the old 800 (on the SD card) to the new 830?
I confess i am not really sure what you mean by OSM. Where do I find those? Do they give similar detail to OS maps?
OSM is Openstreetmap. Your 830 already comes with (versions of) these maps.
What do the other, much smaller, files actually do? Some are SUM files and there is one that is a GMA file, an XML file a BIN file and a Text document file.
The maps need to be in the "\Garmin" folder.
The *.img file is the actual map file. I believe the GMA file is a license/lock file. I don't think the *.txt or *.bin files (if they have the same name as a *.img file) do anything. They might be related to incomplete downloads.
I believe the Ordinance Survey (OS) maps are locked to the microSD card or the device. That is, I don't believe you can just copy them around and get them to work.
Many people in the UK prefer the Ordinance Survey (OS) maps.
The OSM maps have a varying degree of quality, depending on location. It wouldn't surprise me that the OS maps were better.
I like the OSM maps fine (I'm a fairly-regular contributor to updating them).
One advantage of the Garmin devices is that you can install other maps.
Ah, ok thanks. I guess that is a licensing thing. But v irritating since I bought the license! Won't make that mistake again. They are v expensive.
You aren't the first person to get hung up by this. It's the choice of the Ordinance Survey (the provider of the map).
Don't suppose I'll be the last either! Thanks for your help.
