EDGE830: Elevation drift and inaccuracy
Hi there, I am having a problem with my edge 830 device. The elevation is drifting almost randomly. If I set the elevation to say 800mt, even without moving the altimeter starts to drift and current elevation goes to 750mt, then progressively to 600mt (even without moving from the point of calibration). Moreover, when I use it on my bicycle, it tells me totally inaccurate gradients, like it says I am on a +15% gradient climb while I am actually on a perfectly flat road. Clearly this mess causes totally inaccurate calculations for the positive and negative elevation gains (basically, it is useless). I tried to reset the device to default setting but the problem persists. I have software version 8.20. What should I do?
Thanks for you help!
Lorenzo
