Sometimes I run getting pulled by a dog, now I’m getting an e-bike. How do these extra “helps” influence my Vo2 max calculation?
How are they supposed to influence? Edge estimates your VO2max from your heart rate data and power measurement. If on eBike you have a measurement of the power generated by you (not motor power!), The…
Edge is not a runner's device!
The VO2max algorithm for cyclists differs from running activities and requires a heart rate monitor and a power meter. No GPS signal is required, and indoor activities…
The actual formula is not that clear. For example on running the website says:
Is speed considered? If not, why does GPS matter?
https://support.garmin.com/en-US/?faq=lWqSVlq3w76z5WoihLy5f8
The VO2max algorithm for cyclists differs from running activities and requires a heart rate monitor and a power meter. No GPS signal is required, and indoor activities are also estimated.
https://www8.garmin.com/manuals/webhelp/edge830/EN-US/GUID-E7F8B9B6-ED95-49A6-998F-B21DB8DA4734.html
