I hit the "Pause/Start" button on the Garmin Edge 830 and it ended my ride; so now I have two rides: One to the destination and the other from destination home. Is there a way to concatenate the two rides into one single ride?
There is file combiner here
I can tell it concatenated the files because the new target file is almost twice the size; but when I open it, it still only shows one half of the route. So, no, it didn't work.
Zip then insert the files into your post. We can try it.
I've zipped the files but don't see how to attach them to this reply. Insert is looking for URL.
9696165 Directly below that box for the URL is the word "Upload" which will allow you to select a file if you click on it.
Interesting. I didn't see that but it's there now. It's in .z7 format but I renamed it .zip so it would upload.Concatenated Files.zip
9696165, your file "fitfiletools.fit" appears to be a full loop of 68.52 miles. Is that not correct? When using Fit File Repair Tool's "Append" option it also comes out to the same 68.52 mile ride - Appended.fit
Make sure you've deleted the 2 activities from from Garmin Connect before attempting to import the Appended file.
That is correct. I wasn't aware I had to delete the other two files. Thank you for the guidance.When I tried to upload it to Strava it said the ride already existed as well. I'll have to remove the two Strava rides and re-import it.
