As i expected, the 8.00 still contains the previous bugs what i wrote down many times here (too):
#1: GPS LAT/LON position duplication due to bad low priority coding (the cpu doesnt get back new GPS position within 1sec due to bad low priority coding and in this case it is using the latest known position which makes duplication...), i have 19pcs duplicated positions during a 140mins ride (sometimes more, if somebody needs i can check the previous activities with 8.00fw), these duplications happened today within a 4mins window ( between 49.5min - 53.5min), there is no active BT connection during the ride, no route, no segment, no workout, so nothing started in the background. GPS+GALILEO setting but the GNSS setting is irrelevant as i experienced
#2: Record skipping bug , always there is 1 skipped record in the FIT file, today at the 123mins:
| 751800 | 2021. 06. 16. 15:18:02 |
| 751900 | 2021. 06. 16. 15:18:03 |
| 752000 | 2021. 06. 16. 15:18:05 |
| 752100 | 2021. 06. 16. 15:18:06 |
#3: Comm chip (ANT+) resetting, dropped my powermeter, hrm and speed sensor's signal after ~35mins:
| Timestamp | PosLat | PosLong | Altitude | Distance | GPSDistance | HeartRate | Cadence | Speed | Power |
| 2021. 06. 16. 13:49:35 | 47,73636265°N | 9,07911315°E | 449,6 [1] | 17,55112000 [6] | 17,61077000 | 132 [4] | 98 [5] | 51,83 [6] | 228 [5] |
| 2021. 06. 16. 13:49:36 | 47,73623952°N | 9,07915740°E | 449,2 [1] | 17,56558000 [6] | 17,62485000 | 132 [4] | 98 [5] | 52,00 [6] | 211 [5] |
| 2021. 06. 16. 13:49:37 | 47,73611337°N | 9,07918481°E | 448,6 [1] | 17,57992000 [6] | 17,63903000 | 133 [4] | 98 [5] | 51,66 [6] | 217 [5] |
| 2021. 06. 16. 13:49:38 | 47,73598588°N | 9,07919663°E | 448,4 [1] | 17,59433000 [6] | 17,65323000 | 132 [4] | 98 [5] | 51,83 [6] | 0 [5] |
| 2021. 06. 16. 13:49:39 | 47,73585605°N | 9,07919051°E | 448,2 [1] | 17,60873000 [6] | 17,66767000 | 132 [4] | 98 [5] | 51,83 [6] | 0 [5] |
| 2021. 06. 16. 13:49:40 | 47,73572722°N | 9,07916159°E | 448,0 [1] | 17,62312000 [6] | 17,68216000 | 132 [4] | 0 [5] | 51,83 [6] | 0 [5] |
| 2021. 06. 16. 13:49:41 | 47,73560015°N | 9,07911155°E | 447,6 [1] | 17,63773000 [3] | 17,69678000 | 132 [4] | 0 [5] | 51,83 [3] | 0 [5] |
| 2021. 06. 16. 13:49:42 | 47,73547945°N | 9,07903771°E | 447,2 [1] | 17,65222000 [3] | 17,71130000 | 132 [4] | 0 [5] | 52,20 [3] | 0 [5] |
| 2021. 06. 16. 13:49:43 | 47,73536763°N | 9,07894132°E | 446,6 [1] | 17,66658000 [3] | 17,72568000 | 98 [5] | 52,20 [3] | 208 [5] | |
| 2021. 06. 16. 13:49:44 | 47,73526789°N | 9,07882498°E | 445,8 [1] | 17,68068000 [3] | 17,73979000 | 98 [5] | 51,96 [3] | 218 [5] | |
| 2021. 06. 16. 13:49:45 | 47,73518004°N | 9,07869388°E | 445,6 [1] | 17,69454000 [3] | 17,75365000 | 132 [4] | 98 [5] | 51,12 [3] | 218 [5] |
| 2021. 06. 16. 13:49:46 | 47,73510377°N | 9,07854812°E | 445,2 [1] | 17,70795000 [6] | 17,76749000 | 132 [4] | 92 [5] | 48,27 [6] | 218 [5] |
| 2021. 06. 16. 13:49:47 | 47,73503722°N | 9,07839088°E | 445,2 [1] | 17,72115000 [6] | 17,78141000 | 132 [4] | 96 [5] | 47,53 [6] | 205 [5] |
| 2021. 06. 16. 13:49:48 | 47,73498558°N | 9,07822626°E | 445,0 [1] | 17,73423000 [6] | 17,79503000 | 131 [4] | 97 [5] | 46,82 [6] | 222 [5] |
| 2021. 06. 16. 13:49:49 | 47,73494175°N | 9,07805745°E | 445,0 [1] | 17,74705000 [6] | 17,80859000 | 131 [4] | 96 [5] | 46,39 [6] | 224 [5] |
when is the fix expected? still in this century?
