After update Edgo 830 continuously turns on and off. Update damaged Edge 830.
Non-prompted Non-Vol Clear - Clears NV and deletes all FIT files including Activities, Courses, Workouts.
1. Turn device off
2. Hold Lap/Reset and Start/Stop
3. Press and release the power button
4. Continue to hold only Lap/Reset and Start/Stop
5. Release Lap/Reset and Start/Stop when the Garmin Logo is cleared
6. The unit will restart and clear non-vol
Prompted non-Vol Clear - Clears NV and deletes all default FIT files and any files in the NewFiles folder. This will not delete Activities, Courses, or Workouts.
Turn device off
Power device on
While booting up, press and hold upper-left corner of the touch window ONCE the copyright information appears
Continue pressing the left hand corner of the screen until you receive the prompt
"product_name":"Edge 830",
"software_part_number":"006-B3122-00",
"ms_since_epoch":1623828116000,
"system_version":"8.00",
"build_type":"PRODUCTION",
"backtrace":"
Function Address: 0x6035D674
Call Address at Function: 0x6035D83A
Function Address: 0x60989B4A
Call Address at Function: 0x60989C94
"error_cause":"RTL Trap",
"proprietary_info":{
"Commit ID":"d42563d3fdeb3c7a0a8232ea01bb75517dfb1d10",
"Time":"2021-6-16 10:21:56",
"Project Specific":"2021-6-16 10:21:56",
"CDP_LOG":"60609FD1,604686D5,",
"RTL Error Number":"6E5D8024",
"Error Message":"00000000,D00A27C9,0000217B,00000000,632195BE,632195B0,632195B1,1AAE5F00,0000004C,D07C2700,D07BEA50,D07C2708,63218C2C,63218C30,60386135,6035D83A,0000003F",
"Task Name":"MPM main",
"Saved SP":"63218C30",
"Saved LR":"60386135",
"Saved PC":"6035D83A",
"R[0]":"00000000",
"R[1]":"D00A27C9",
"R[2]":"0000217B",
"R[3]":"00000000",
"R[4]":"632195BE",
"R[5]":"632195B0",
"R[6]":"632195B1",
"R[7]":"1AAE5F00",
"R[8]":"0000004C",
"R[9]":"D07C2700",
"R[10]":"D07BEA50",
"R[11]":"D07C2708",
"R[12]":"63218C2C",
"R[13]":"63218C30",
"R[14]":"60386135",
"R[15]":"6035D83A",
"cpsr":"0000003F"
Also, after setting up the device, the reboot resumed(
Back to 7.1
I decided to overcome it)
I installed 7.1, reset it through the menu, connected GE and received the update there was no reboot.
I reset it again and set up the device.
While the flight is normal)
I have reinstalled custom map. and switched off the Strava segments. present time it's working OK, but without segments. if it's not hard to you pls give Link how change back to fw 7.10. (yes my update arrive via telephone). thnx
Disable automatic updates
