Synchronise Course created in device to Garmin Connect
Hi!
I created a course in the device itself, I have been trying to use the Garmin Connect app to sync it from the device to the application, but it doesn't work using any of the "Sync" buttons in the phone app.
How to do it?
Thanks!
Top Replies
  • If you created a course on your 830 from a previous ride that you've recorded, this will be in the Garmin > Courses folder with the same title you chose when you saved the course. You will have…
All Replies
  • You can't as far as I know.  If you have ridden the course you can use that ride to create the course in Connect.
  • You can manually import the file from the Edge unit.
    in the folder \Garmin\Courses\ you find it, and i connect, Select => Training => Courses => Import
  • Courses created on the device don't create files in \Garmin\Courses.
    If you create a course from an activity, that course file does get saved in \Garmin\Courses.
    If you have the file in \Garmin\Courses, you have it somewhere else (unless, you got it from a device-to-device transfer).
  • If you created a course on your 830 from a previous ride that you've recorded, this will be in the Garmin > Courses folder with the same title you chose when you saved the course. You will have to access this on your computer and upload it manually into Garmin Connect as we currently do not have the ability to automatically sync those over.
