Course in two days Edge 830
I uploaded a course of 350km on my Garmin 830. After 200km I decided to search for a hotel and ended my recording. I cycled to my Hotel and the next day I wanted to continue my course. The only option I get is to start from the beginning of the course again. Is it also possible to navigate to the point where I stopt the day before and than continue from there?
  • If you load the course and reject the navigation to start the Edge will start processing it as soon as you get on the course.
    You would need to know where to rejoin it from.
  • The only option is, not to miss to store your actual location. You can use that as destination and navigate there.
    You can then start your course and just decline to navigate to the start point. I should tell you when it is on track and continue.
    Regarding the recording. First - just keep in mind following the course and recordiing is totally indiependent.
    Did you just stop the recording, or diid you confirm to save? As long as you only stop and not save you can continue by pressing the start button.
