Bonjour. Lors de mes sorties mon compteur se met en pause et repart seul quelque soit la vitesse à laquelle je roule. Quelqu'un aurait-il 1 solution pour palier à ce petit désagrément ?
First: consider posting in English in this forum
Have you auto-start/stop enabled? If so: at what speed?
Do you have a speed sensor (coupled)? When not and riding under trees, between high building it might be that incorrect speed is registered and you Garmin thinks it stopped.
Hi my Garmin Fu**ing Edge 830 does the same. Auto stop is disable but it happens sometimes without any reason. I must stop the activity, turning off the shi**y computer and turning it on and restart another activity.
I have this computer since less than one year and this is the badest product I've ever bought for biking.
I really wasted my money.
Of course the battery is good because when I restart the computer it works 'till the end of the session and works well for hundreds km until with no reason again it pauses while riding at 30 or 25 km/h without any reason. It becer happenend with my previous computer.
Same for my 830... it stops/starts when Im riding, in any speed range. If I have bip enabled it bips to times in les than a couple of seconds. Also when the bike is totally stop it bips twice, very frustrating.
The only 'solution' I found was to disable auto pause when stopped, but I like this function enabled.
Time to send device to Garmin for repair?
[PROBLEM FOUND] I think there is an issue with the use of speed sensor. 830 runs fine if I disable my speed sensor!
It is not a matter of sensor battery, as mine is the one integrated in my Turbo Levo, with full 700W battery!
Can anyone share his experience with this topic?
