Edge 830 Asia - loosing connectivity to sensors sporadically
I have a Edge 830 Asia model, which I updated to version 6.20 from 5.60. No issue at all with version 5.60, but after upgrade, device looses connection for a few seconds with sensor after riding for a while before reconnecting. Disconnection/ reconnection cycle happens sporadically. Strangely this is only happening with my cadence/ Speed sensor connected via ANT+. No issue at all with the hearth sensor (also connected via ANT+).
I changed the battery of the sensor, repaired the sensors, reseted the device = still happening.
Last hope is to downgrade to version 5.60 = I have been trying to find the GUPDATE.GCD file = no success so far. Only the 6.20 is available on the Garmin Asia site.
Note: the 5.60 version on Garmin generic site seems to be not compatible with the Asia localisation of the Edge 830. I was not able to use this version.
Does anyone experienced the same issue? Any solution or clue where I can find the 5.60 version for the Asia model?
Thanks!
