When on my first ride today with Garmin 830 (and RTL 515). Coming from a long time Edge 800 user I am still trying to figure out some of the nuances and differences other than the obvious.
Can anyone tell me what the colored (green and red/yellow) box outlines are for when you start/stop the timer?
Timer Start Mode - How does Prompted work? Do I get a message to manually start once I reach 6mph? That being the case what is the Manual setting then?
I rode for just over 2 hrs. with Varia light/radar running as well. I did have the backlight up to about 90% due to current ambient sunlight. I started with full 100% charged battery. At end of ride my battery level was only 56%. I was not connected to any other apps other than Varia. Is this huge battery drain normal? My Edge 800 with max screen brightness would maybe only drop about 15% after 2 hours.
My biggest concern is the total lack of volume with beep notification. I have already posted this concern before I even took a ride based on other users' comments on multiple forums but did not realize how bad it would be. Once I got to speeds around 10-12mph forget about hearing the notifications (mainly from Varia radar being sent as cars approached). I have the 830 mounted as close to me as possible on top of the bar but still very weak compared to my 800. Is this as good as it will get?
I think I will really like this upgrade as soon as I have everything figured out but time will tell. Appreciate any comments and recommendations.
