Hi,
Garmin-Matthew can You tell me why has it ~8sec delay? (i noticed it 2 months ago just i was lazy to reporting it but it is annoying now...) i compared my 4 devices, depending on GPS timestamps, here is the result : (we rode next to each other btw...) i dont use BT connection , the Edge 830 is using GPS+GALILEO setting only
#1: Strava flyby, showing ~8s delay , BUT ON THE 830 THE "time of day" DATAFIELD IS SHOWING EXACTLY THE SAME TIME as on my other /Garmin/ devices, then WHY did it write different GPS timestamp into the FIT file??? It looks like (as i opened both FIT files with editor) the EDGE 830 is adding 8sec to the timestamps everywhere , i started my both Garmins in same time (as i wrote, the time of day datafield is showing exaclty the same time on all of the 4 units, it is changing the minutes in same time) . So why does it add this 8secs from the program code unnecessary?
#2: QS comparison with 4 devices: it is clearly showing that only the 830 is delaying with 8secs apprx
BR,
Andras
