Edge 830 will not show BLE sensors
I have 2 sets of 4iii dual power meters. I want to try BLE as I get drop outs sometimes to see if it is more stable.
On the Edge 830, they will never show a BLE connection on searching. Both power meters connect fine via Bluetooth on my phone.
Is there anything I need to do to make them show up as BLE on the 830?
  • Do not pair them to your phone otherwise the Edge wont see them because only one connection is allowed via BT (via ANT+ You can connect the 4iiiis to multiple devices)
    0 Former Member in reply to Luko79
    Thank you. I did try this as well.
    it appears something to do with the edge 830. I tried on a 1030 Plus and the BLE connection showed instantly in adding sensors. Will try resetting the 830..
    Just to add an update after using 1030 plus now.
    • 1030 plus is way more stable on ANT+, on the 830 I always had HRM and Power meter drop outs across bikes. With the 1030 plus this has not happened at all, which is a relief as I rely on power and HRM MI whilst training
    • 830 does not find BLE but 1030 plus does fine
    I am keeping the 1030 plus as my main for training (screen size helps too). Will reset the 830 to keep for commuting and see if that helps
