After installation of new firmware 6.00 i've noticed some excessive battery drain. Usually the battery consumption was 6/7% per hour. Now is 10/11%. Same sensors, same usage, same routes. Someone experienced the same????
No, still at 5%/H
i have 2.4% per hour (with powermeter, speed sensor, hr sensor) without BT and without any course following (sometimes 2-3 strava segments are popping up per ride but nothing else).
I suggest to delete the…
I noticed under display settings that the backlight was toggled to always on. Pretty sure that is my issue.
The battery seems to drain quicker after the update. This is with all settings the same for me. Backlight on and auto brightness. GPS on. Certainly I would think that by disabling either of these things it would reduce the drain but that doesn’t mean it’s the cause. My guess is it’s something they’re doing different to maintain connections.
That said, it’s still way better than my 800.
