Thanks Matthew for having the FW 6.00 download available in your forum post!
Had the same issue. The GPS Software was Stuck on 2.90 (with a "!" on the info screen) and Galileo was gone. Since on the edge there was nothing in the update-menu, I connected the Edge to Garmin Express…
Nothing about intensy minutes, nothing about the faulty physio true up. The device will remain in the box.
intensity minutes have nothing to do with Edge 830, it's part of a Garmin watch…
and True Up without Physio is something different, if you have multiple activity trackers (Edge isn't a Activity Tracker):
https://support.garmin.com/en-US/?faq=a2uguZzTQG4I2HTBvHa0gA
Doing a factory reset when using FW 6, cured radar disconnections, and the problem I had with the radar's light switching itself off and on at various times.
It didn't fix things like "Time to Destination" or "ETA" when navigating a course. They're totally F'd up.
"Distance to Destination" works OK though. Just not any time based data.
Garmin-Matthew, Garmin-Enrique (Mr.Gonzales might not be working in Garmin anymore as one can see his login name ;) that renders picture of how are things at Garmin's end maintained... poor/well... your choice
You and all Garmin can stick up all your work you know where. I'd love to throw all the gadgets worth 1000GBP+ to your face...
the best ride I had since covid and with the latest FW for Edge and/or Fenix 6x, Varia, HRM TRI, 2 speed sensors, 2 cadence sensors all is down south....
pretty much keeping my ride in hr zone 4 and training benefit values are shite! Anaerobic 0.0, aerobic 0.8 accompanied with the load of 11? Y'all must be smoking some good stuff!
I am so pissed!!! It makes me to sign up for any social media and just spit it out all...
You are running out the betas to people relying on providing all the feedbacks / error logs (Debugging), etc. I also shared, it feels like money in vain... but this is not getting even close 'the more the merrier'...
I'd recommend you to anyone again and discourage to ever use your products ever. Former Member (by this I meant Garmin United Kingdom)
I’ve had the same. Usually I get the radar disconnected prompt, then within a minute or two it all locks up and I need to hold the power button to hard reset. Happened twice now since installing 6.00. Never had a crash in nearly a years use till now.
still no probs with RTL511
same to me ! disc with 515
could be an issue of Radar FW?
how you connect? (ANT+ or BLT)
RTL 511 is connected with ANT+ only here
only ant+
i have also di2 dic all the time (ant+)
with beta all was working fine but with 6 all mess up
