I'm having issues with the Edge830 not auto detecting my RTL515 (Radar & Light). I do have a UT800 headlight and RTL515 radar channels paired, but RTL515 light channel is not available for paring. Even when I remove the 515 and then add Sensors using "search all" option, only the Radar channel is available for pairing.
Turning on my Edge830, the lighting network only forms with UT800. Even with the blue light double flashing, the RTL515 radar will not auto connect. It is not until I depress the power button which fires up the torch along with the radar which is eventually recognized by the Edge830. The light portion is not controllable by the Edge830
As I'm reading in other threads and forums, it's as if only one light channel can be paired and controlled by the Edge830.
Any thoughts or help would be appreciated.
Software versions:
Edge 830 - 5.51 (beta)
RTL515 - 3.20 (current)
UT800 - 2.40 (current)
