Edge 830 Segment Explore Widget
How is this really supposed to work? The Garmin user manual is so brief and lacking in details on certain things and especially screen shots, which would make it so clear.
1. Is the list of segments supposed to dynamically change with your location? I would think so, but on my last ride, whenever I checked them, I got the same list no matter where I was.
2a If I selected a segment and pressed "download" I either got a message saying the segment would be available after my activity was completed (that sort of defeats the purpose) or download failed.
2b OK, in my back yard I was able to download some segments. Start button was not pressed, if that means anything. Also I was probably within range of WiFi. Then, another little thing: if you press the button "Ride", it loads that segment on a map, BUT also seems to show on that same map all the other segments that you had starred. Is this documented anywhere?
I am at Software version 5.5
Thanks in advance to all who respond!
