Hello from Campagnolo EPS support. I'm Andrea Armellini, I work in Campagnolo in EPS division.
I think I found a bug in 830 and 530 devices (and I suppose with all x30 devices) with our Campagnolo groupset.
The bug is related to activity registration and fit file exported that don't have the right data concernig the gear sensor. In our app we use API to Garmin Connect to retrieve registered session to analyze gear data, and i found incoerent data.
Scenario:
I'm going to register activity with Fenix 5, Garmin Edge 530, Garmin Edge 830, Garmin Edge 520, Wahoo Elemnt Bolt. In all deviced I add the gear sensor using ANT+ protocol (i'm testing with our Campagnolo 12 EPS groupset, updated with the last firmware).
In the gear option page, in all Garmin devices (except the wahoo that doesn't have this option) I configure the sensor details as following:
Front Gears (2): Gear 1 (36), Gear 2 (52)
Rear Gears (12): Gear 1 (32), Gear 2 (28), Gear 3 (25), Gear 4 (22), Gear 5 (19), Gear 6 (17), Gear 7 (16), Gear 8 (15), Gear 9 (14), Gear 10 (13), Gear 11 (12), Gear 12 (11)
Details correspond to chainring teeth
During registration I tried different combination and multishifting.
I than connected all devices to my pc to export fit file of the registered activity.
I converted fit files to CSV using the appropriate tool from Fit SDK and i opened with excel. I searched in the raw for the event "gear_change_data" and look at the results
Garmin Edge 520, Fenix 5 and Wahoo exhibit the same behavior. I had values from 1 to 12 from "rear_gear_num" and the corrispondence with assigned theeth numbers. I had values from 1 to 2 from "front_gear_num" with assigned theeth numbers (36 or 52)
Garmin Edge 530 and Garmin edge 830 show different values: they use different scale of values. Rear_gear_num going from 0 t o11, and front_gear_num going from 0 to 1 (in some rare case I had dirty values from 0 to 2).
The problem appears after front derail.
As you see, we get front_gear_num = 0 (it would be 2) and front_gear = 255 (both on 530 and 830), and they are inverted in 530 and 830 (it show 52, but I'm on 36)
In the hud in Garmin 530 and 830 in relative page fiedl and graph data and position correspond to the reality
| Data | 3 | event | timestamp | 959425468 | s | gear_change_data | 604050948 | event | 43 | event_type | 3 | rear_gear_num | 4 | rear_gear | 22 | front_gear_num | 1 | front_gear | 36 | ||||||
| Data | 3 | event | timestamp | 959425472 | s | gear_change_data | 4278195716 | event | 42 | event_type | 3 | rear_gear_num | 4 | rear_gear | 22 | front_gear_num | 0 | front_gear | 255 |
In 520, Fenix:
| Data | 2 | event | timestamp | 959425468 | s | gear_change_data | 872551173 | event | 43 | event_type | 3 | rear_gear_num | 5 | rear_gear | 19 | front_gear_num | 2 | front_gear | 52 | ||||||
| Data | 2 | event | timestamp | 959425472 | s | gear_change_data | 604050181 | event | 42 | event_type | 3 | rear_gear_num | 5 | rear_gear | 19 | front_gear_num | 1 | front_gear | 36 |
In wahoo io have same data as 520 and Fenix, but in different column. It report the right front_gear_num, 1 and 2
Please could you check if there is a sort of bug in Garmin x30 devices with ANT+ broadcast message and Campagnolo groupset?
