I am curious. If I have two or more HR sensors in the 830 sensor pool, and more than one are available, what does the 830 do? Does it use the first one it finds?
I think you have to select one.
From the home screen: Menu > Sensors > (select a HR sensor) > (Enable if necessary, then Connect)
It will use the first one it finds. You can go into the sensors menu as asmcdaniel mentioned and connect to a different one if you wish to use a specific one.
