Hi,
I did a short hike (I was walking, not bilking, Garmin Edge 830 was on the top of my backpack) and the distance displayed by Edge 830 was totally wrong!. I know that correct total distance is about 11 kilometers, but Edge 830 displayed 4,75 km. I compared this to my daughters Garmin watch and her distance was about 11 km (which is correct!). The distance calculated by Edge 830 is also displayed in Garmin Connect and in Strava. I believe that this data is written in FIT file and transferred elsewhere.
And now the surprise. I exported GPX data for the hike and import the file in different GPX viewers - they all calculate the correct distance (which is 10,9 km). So I can conclude that the GPX points are stored correctly (I use 1 second interval), but Edge 830 for some reason does not sum the distance correctly.
To summarize:
1) Garmin Edge 830 displays wrong distance on several occasions (I have described in detail just one instance - 4.75 km instead of 10,9 km.
2) This (wrong!) distance is transferred to Garmin Connect and Strava (very probable by FIT file)
3) All GPX points are correctly recorded by Edge 830 and the distance calculated from these points using different apps on www is correct.
Any suggestions? Advice?
Best regards,
Viljem
